11-02-2017 11:39 AM
The IP comes with these 2 parameters:
PSU__NUM_F2P0__INTR__INPUTS == 2
PSU__NUM_F2P1__INTR__INPUTS == 1
while the Technical Reference Manual states:
"Except for IRQ(121) through IRQ(128) and IRQ(136) through IRQ(144), which are the interrupts from the PL,"
Shouldn't the IP have been released with the above 2 parameters set to 8?
11-03-2017 09:28 AM
Here's a example recipe to see the 16 PL to PS interrupts. Exact filenames may differ.
1) Quit vivado
2) Edit these 3 files and change the 2 parameters to 8:
<project>.srcs/sources_1/bd/design_1/design_1.bd
<project>.srcs/sources_1/bd/design_1/hw_handoff/design_1.hwh
<project>.srcs/sources_1/bd/design_1/ip/design_1_zynq_ultra_ps_e_0_0/design_1_synq_ultra_ps_e_0_0.xci
3) Start vivado, open block diagram. The zynq ultra will complain that the IP is out of date. Update it.
4) Now note the 8 inputs available on the zynq block for IRQ0 and IRQ1 (if you have them enabled in the zynq block config).
11-03-2017 12:23 PM
Looks like another 2017.3 snafu. I assume you're also getting this warning:
The width of the ps_pl_irqN[0:0] port(s) should be updated automatically with the attached bus, when the block diagram products are generated.
However, 2017.3 (V3.1), bad:
Instead of 2017.2 (V3.0) good:
If reverting back to 2017.2 isn't an option, it looks like you might need to continue hacking the output products.
-Joe G.
11-20-2017 01:12 PM
I'm seeing the same issue in 2017.3. PL_PS_IRQ0 auto-sizes up to 8-bits, but PL_PS_IRQ1 has a max width of only 4 bits. I edited the three files suggested by the OP and all 8-bits are now available on IRQ1. I fear my edits will be overwritten by Vivado if I make a change to the PS.
11-20-2017 01:21 PM
I think I recently ran a trial design in 2017.3.1--with the new update. And I'm pretty sure that version correctly handled the interrupt port auto-adjustment.
-Joe G.
01-18-2018 11:59 PM
This a known issue. please try the following solution or delete the old PS8 instance then add a new one
