cor
Zynq ultrascale+ clocking
I'm new to the Zynq Ultrascale family. And I'm a bit confused about how to clock the PL stuff.
The PS can generate 4 clocks. Is this mend to clock all kind of PL stuff? Or is this mainly mend for the axi busses?
I need for instance a low jitter 200MHz clock for MIPI interfaces. Can I use the PS clocking system for that? Or is that not the way to go and should I use an external oscillator connected to the FPGA and use a PLL or MMCM to generate this clock?
If so, what are the clock inputs to use? I do not see dedicated clock inputs.
And how to generate a general purpose 150MHz PL clock without jitter requirements. Using the PS output clocks for this is fine?
