01-22-2020 07:10 AM
I am using http://www.wiki.xilinx.com/ZynqMp+USB+Stadalone+Driver.
I want to evalute the USB3.0 device regarding performance and the access from Windows drivers.
When I connect the port to the PC the USB device identifies as USB2.0 and not as USB3.0
I see in the code that super speed is been configured but in the initialization phase the value read from XUSBPSU_DSTS register is always XUSBPSU_DCFG_HIGHSPEED.
01-29-2020 06:37 AM
Hi Yoichi,
We used the PetaLinux example and still we saw that the EVB is discovered as USB2.0.
But we replaced the cable we a diffrent cable and now we see that it is identifed as USB3.1 and we get USB 3.1 performance
Thank you
01-24-2020 09:26 PM - edited 01-24-2020 09:26 PM
Hello @rani.feldman
This may not be the solution. This is a reference only.
Thank you
Yoichi
This forum is based on the cooperation of everyone who participates.
Kindly note - Please mark the Answer as "Accept as solution" if information provided is helpful.
01-26-2020 05:36 AM
Hi Yoichi,
I am using production ZCU102 kit, so I should not have this issue.
01-27-2020 03:32 AM
This AR has the following description.
http://www.whizzsystems.com/usb3-micro-b-plug-adapter
This adapter is shipped with production ZCU102 kits.
Customers should also always use the Targus ACH124 USB hub shipped with the kit.
Did you use that?
Yoichi
01-28-2020 04:01 AM
Sorry, I do not have this adapter.
I do not have it in my kit.
01-29-2020 06:37 AM
Hi Yoichi,
Thank you
