ggillett
axi dma reset behvior
I am testing some DMA designs and have run into some perplexing reset behavior. The relevant part of the BD is
axis_counter counts to some value asserting last at that value, it asserts valid one clock after coming out of reset (peripheral_aresetn). The axi_dma reset is connected to interconnect_aresetn.
The issue is that axi_dma seems to expect 4 data beats after coming out of reset,
What is the dma IP expecting? The axi_dma registers are not changed by any of my test code, ext_reset_in to the reset IP is controlled through GPIO.
RegisterMap {
  MM2S_DMACR = Register(RS=0, Reset=0, Keyhole=0, Cyclic_BD_Enable=0,
      IOC_IrqEn=0, Dly_IrqEn=0, Err_IrqEn=0, IRQThreshold=0, IRQDelay=0),
  MM2S_DMASR = Register(Halted=0, Idle=0, SGIncld=0, DMAIntErr=0,
    DMASlvErr=0, DMADecErr=0, SGIntErr=0, SGSlvErr=0, SGDecErr=0, IOC_Irq=0,
    Dly_Irq=0, Err_Irq=0, IRQThresholdSts=0, IRQDelaySts=0),
MM2S_CURDESC = Register(Current_Descriptor_Pointer=0),
MM2S_CURDESC_MSB = Register(Current_Descriptor_Pointer=0),
MM2S_TAILDESC = Register(Tail_Descriptor_Pointer=0),
MM2S_TAILDESC_MSB = Register(Tail_Descriptor_Pointer=0),
MM2S_SA = Register(Source_Address=0),
MM2S_SA_MSB = Register(Source_Address=0),
MM2S_LENGTH = Register(Length=0),
SG_CTL = Register(SG_CACHE=0, SG_USER=0),
S2MM_DMACR = Register(RS=0, Reset=0, Keyhole=0, Cyclic_BD_Enable=0, IOC_IrqEn=0,
Dly_IrqEn=0, Err_IrqEn=0, IRQThreshold=1, IRQDelay=0),
S2MM_DMASR = Register(Halted=1, Idle=0, SGIncld=0, DMAIntErr=0, DMASlvErr=0,
DMADecErr=0, SGIntErr=0, SGSlvErr=0, SGDecErr=0, IOC_Irq=0, Dly_Irq=0, Err_Irq=0,
S2MM_CURDESC = Register(Current_Descriptor_Pointer=0),
S2MM_CURDESC_MSB = Register(Current_Descriptor_Pointer=0),
S2MM_TAILDESC = Register(Tail_Descriptor_Pointer=0),
S2MM_TAILDESC_MSB = Register(Tail_Descriptor_Pointer=0),
S2MM_DA = Register(Destination_Address=0),
S2MM_DA_MSB = Register(Destination_Address=0),
S2MM_LENGTH = Register(Length=0)
Any insight appreciated.
Tags (2)
tedbooth
@ggillett
I would suspect that it is the AXIS interface logic on the input of the AXI DMA.  The AXIS interface logic is essentially a FIFO with a small amount of buffering.  I've seen similar behavior on multiple IPs with AXIS inputs.
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
tedbooth
@ggillett
ggillett
Thanks that makes sense, the FIFO FWFT, register slices or what ever other buffering is ready and fills with the 4 data beats.
The issue is when I perform a transfer that buffered data is missing and the buffer starts at 4. I'll check that I am setting up things correctly through PYNQ.
tedbooth
@ggillett
It is my understanding that the AXI DMA does not like it when data arrives before it is configured and running.  You might want to add a small bit of logic to control the flow of data on that channel.  Have it default to disabled until the AXI DMA is running and then enable it.
ggillett
Hmm thanks for the heads up, don't particularly like the sound of that though.
