vadlamudianil
burst length
could you please clarify difference between beat, Burst_size, Burst_Length, Data_Beat
what is the maximum number of bytes in Beat,
how many number of data transfers in each burst length
muravin
"Data Beat" is the amount data transferred in a single clock cycle on the AXI bus.
"Data Transfer" = "Data Beat"
So if the AXI bus is 512-bit wide, a data beat has 64 bytes in it.
"Burst Length" is the number of the data beats in a single AXI burst
"Burst Size" - it is the maximum number of bytes that can be transferred in a data beat
Hope this helps
Vlad
Vladislav Muravin
dwisehart
What are you looking at?
muravin
Hope this helps
Vlad
Vladislav Muravin
vortex1601
These are described in detail in the AXI spec.
You use these fields to control local (target) address generation and to determine when a transfer is finished.
Summary:
AxLEN[7:0] = # of beats in a transfer, minus one. (0 = 1 beat, 1 = 2 beats ... 255 = 256 beats, the max allowed.)
AxSIZE[2:0] = size of a beat, as 2^n (0 = 1 byte, 1 = 2 bytes, 2 = 4 bytes, 3 = 8 bytes... 7 = 128 bytes)
AxBURST = addressing mode. (0 = INCR (as for a RAM), 1 = FIXED (as for a FIFO), 2 = WRAP (for a circular buffer), 3 is reserved)
