JohnsonHu
coefficient files for traffic_gen are not up to date
It's a convenient to have traffic_gen to initial the IP's via coefficient files via axi_lite interface.
I need to modify the coefficient files (atg_addr.coe, atg_data.coe, etc)  and re-run the simulation to verify the developing modules.
I tried to "close the simulation", "close the project", even "re-enter the Vivado" to let the simulator re-load the new coefficient files; however, the updated coe files seems not be updated, from the inspection of m_axi_lite* signals.
Please help.
Johnson
florentw
Hi @JohnsonHu
If you are using a Block Design (BD), you will probably need to reset and re-generate the BD output products.
If you are not using a BD you will probably need to regenerate the IP output products
florentw
Hi @JohnsonHu
