could I adjust the frequency of ynq-7000 SOC below 667MHz
I want  to know whether Zynq-7000 SOC can work at 667MHzm, 800MHz and 1GHz or not. And could I adjust the frequency of A9 core below 667MHz and make this SOC work normally? I want to make SOC work at low frequentcy and low energy consumption. if we can adjust the frequency of A9 core below 667MHz, what do I need to do? Need I modified a lot of code of driver or something else.
Thank you
Re: could I adjust the frequency of ynq-7000 SOC below 667MHz
Hi @jeepe,
for Question "I want  to know whether Zynq-7000 SOC can work at 667MHzm, 800MHz and 1GHz or not"?
Yes, Zynq can work upto 1 GHz but it limited for only Z-7030, Z-7035,Z-7054 with speed grade -3. check below clock_zynq.PNG
Yes, you can adjust the core frequency below 667 MHz.
see the below image
Here the range is from 50-800 MHz , you can set the core frequency in between these frequencies and no need to modify driver codes or any other stuff.
Best Regards,
Srikanth
Hi @jeepe,
see the below image
Best Regards,
Srikanth
Thank you very much, and what can I do if I want to realize a low energy consumption FPGA board except adjust the frequency. For example, can i modify voltage supply or something else. (I don't care about the working speed no matter how bad it is)
Hi @jeepe,
Please check this AR61980   https://www.xilinx.com/support/answers/61980.html
Here it is discussed about the  low energy consumption techniques for the Zynq7000 devices.
Best Regards,
Srikanth
