exclusive access in microblaze
Does any know how to enable exclusive access options for microblaze AXI DP??
Re: exclusive access in microblaze
Hi @dipslg ,
Exclusive access is enabled using the two parameters C_M_AXI_DP_EXCLUSIVE_ACCESS and C_M_AXI_DC_EXCLUSIVE_ACCESS for the peripheral and cache interconnect, respectively
AXI4: Used to allow exclusive access when C_M_AXI_DP_EXCLUSIVE_ACCESS is 1
Please refer ug984 (v2018.3), page no.259 for reference.
Thanks & Regards
Anil B
@abommera
Thanks for replying. I have gone through this before. But the thing is in the block diagram there is no option to enable exclusive access. If I see the properties of the signal M_AXI_DP of microblaze than only AXI4LITE is enabled and no way I can change the option. In the VHDL code generated by the processor, I can see the option C_M_AXI_DP_EXCLUSIVE_ACCESS. So the qustion is if I alter the vhdl code and make the value to 1,  I am afraid it will do any changes with that I think I need to change the protocol setting of the microblaze and make it AXI4 and not sure what other signals need to be changed.
