execution time of c code
Currently i am working on Zygo(Zync702) board and i want to find the time taken by print function to put strings on Uart terminal, in my c code. Is there any way like SysTick timer of ARM Processor to find the time taken by a set of C code?
Basically i want to know the execution time of instructions.
Thanks in advance.
Re: execution time of c code
Hi @creative1,
If you want to calculate the time taken to execute a piece of code, have to included timers in the hardware design.
Later at software application below reference will help you to do calculate the execution time.
You can use the following template:
#include xtime_l.h
Xtime tStart, tEnd;
Xtime_GetTime(&tStart);
Xtime_GetTime(&tEnd);
Printf("Output took %llu clock cycles. \n", 2*(tEnd-tStart));
ElapsedTime=1.0*(tEnd-tStart)/(COUNTS_PER_SECOND);
Printf("Output took %.2f s.\n",ElapsedTime);
Praveen
hi ,
yes this can be done. I wonder if i could have used arm's systick timer.
Anyway thank you for the reply:)
