fixed to float
I am writing some fixed-point numbers to the DDR memory using memcpy in Vivado HLS. This HLS design is then exported to Vivado, where it is connected to microblaze,MIG 7 series block and UARTlite. Then in SDK I am trying to access those numbers from DDR memory which are being written by HLS IP using Xil_IN32 command. I am successfully able to print these fixed point numbers in hexadecimal format. Now, I want to convert these numbers in type 'float'. I am using following mentioned function from header file "ap_fixed.h" for the purpose:
var_name.to_float()
And when I print these numbers in float, nothing is being printed in SDK terminal. What could be the reason? Can anyone suggest something?
HLS Code:
#include "ap_fixed.h"
typedef ap_fixed <32,15> fixed;
void fixed_pt1(volatile fixed * inpt)
#pragma HLS INTERFACE m_axi depth=5 port=inpt offset=direct
fixed data[5] = {1.0, 1.5, 2.48, 11.09, 1.369369369};
memcpy((fixed*)(inpt), data, 5*sizeof(fixed));
SDK Code:
int main()
fixed arr;
float temp;
u32 base = XPAR_MICROBLAZE_0_DCACHE_BASEADDR+0x00300000;
for (int i=0; i<5; i++){
 arr = (fixed)Xil_In32(base+4*i);
 temp = arr.to_float();
 printf("Data[%d] is %.11f\r\n", i, temp);
return 0;
Re: fixed to float
@kritika117
I could be wrong, but I don't think that you can use the "ap_fixed" data types in the SDK environment.  I think it's only for the the HLS environment.  Someone please correct me if I am wrong on this.
You might try something like:
float arr;
float temp;
 arr = (float)Xil_In32(base+4*i);
 temp = arr>>17;
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
Re: fixed to float
@tedbooth
Thanks for replying.
But, I think we can use 'ap_fixed.h' header file in SDK. We just have to add the path of Vivado_hls include in C/C++ build settings.
