how to integrate microblaze with a verilog design in ISE
hi all
basically i am part of a project and was suppose to receive data through LAN on a spartan 3e sarter kit i used microblaze for that, at the same time there are some other guys who have done some programming in verilog so i want to transfer the received data to the verilog created system from microblaze.
can u please give some pointers as to how that can be done.
i basically want that the rest of the system be completed in ISE instead of XPS if possible.
detailed help is really what i need.
Re: how to integrate microblaze with a verilog design in ISE
Hello.
Just do as you have been doing your projects only select preferred language as verilog instead of VHDL when you create new project in ISE. After this when you attach your EDK project to ISE then instantiate template will generate the instantiation module in verilog only.
Best of luck.
Unlimited in my Limits.
