sixinglu
microblaze stall when enable interruption
Hi all,
I am implementing xapp1026 socket on xilkernel.
But when running, it get stuck into xilkernel_main()->xilkernel_start ()->Xil_ExceptionEnable()-> microblaze_enable_interrupts()->microblaze_enable_interrupts:
                                                     #Load register r12
                                                     lwi r12, r1, 0
Then stuck and never go into main_thread().
I am sure PARAMETER STATIC_PTHREAD_TABLE = ((main_thread,1)) is in system.mss
What's more, when I stop the process, it stop at disable_caches() in cleanup_platform();
Do I need ignore some important interruption or cache setting?
My board is spartan-6 XL45, SDK14.6
Thank you very much!
sixinglu
I solve this problem.
The reason R1 will cause stall is because of stack overflow.
So I check the lscript.ld, find the problem.
sixinglu
