microblaze
hi
can someone give me a tutorial for total dummies on how to create implement and use microblaze?
thanks
hi,
you can use EDK CTT if you have XPS installed. http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/edk_ctt.pdf
you can use this Microblaze hardware guide if using vivado.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_1/ug940-vivado-tutorial-embedded-design.pdf
--hem
Hi everyone,
I'm completly new to microblaze and try to use this tutorial:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug940-vivado-tutorial-embedded-design.pdf
So far everything is okay but when trying to create "New Project" I'm getting the error "Project cannot be create" (see attached screenshot). This is true for all available templates.
Here is also the SDK logfile, I'm using 2015.1
Currently I'm stuck because I can't get the basic stuff working...
    Martin
Was able to find the issue, seems to be a missing 32bit library...
On my CentOS system this helped:
yum install zlib.i686
                Martin
