jalalba
problem with BRPR and BTR registers in CAN V3.2 core
I'm use a CAN V3.2 core.
when I'm in config mode,write in the BPRP (0x008) and BTR (0x00c) registers then read these.
I'm see value of these registers equal to 0. where is the problem؟
my state is:
1-config mode: write X"00000000" to SSR register  (0x00 )
2-set prescaler value: write x"00000001" to BPRP register (0x008)
3-set bit timing register : write x"00000027" to BTR register (0x00c)
4-read BPRP register (0x008)   brp=x"00000000" !!!!???
5- read BTR register(0x00c)  btr = X"00000000" !!!???
Tags (4)
venui
Can you please let me know which device are you using and possible please share your source code?
Venu
