random activation of signal s00_awvalid
Hello, I've designed an IP that has a simple slave. The problem is that I can't synchronize the data arrival with the address arrival. The data arrives faster than the addresses.
I see on the image below after the first address has been transmitted the axi_wvalid signal is not activated for the second address and also the addresses are continuously repeated in the axi_awaddr signal. Can you explain why the signal axi_wvalid behaves like that? Thanks
2020-07-12 06_08_20-X2GO-kamtchogom-50-1593501017_stDMATE_dp32@ls12-nvm-oma1.png
Tags (2)
