  Does the microblaze processor have a method (or set of instructions) to produce the same functionality as the x86 rdtsc() function?  I don't seem to see anything in the microblaze ISA.
  crono
Re: rdtsc()
The microblaze does not have an internal timer counter.  Your EDK system needs to include an XPS Timer peripheral to provide this functionality.
-Brian
Re: rdtsc()
-Brian
Re: rdtsc()
Hi, sorry.  I know I marked this as solved, but could someone please post some sample code on how to access the timer and any header files or libraries I would need to include?  I'm using XPS 11.1  I assume you just do a read from the timer, I just don't know the function call used.  Thanks alot!
Message Edited by crono123 on 08-03-2009 10:11 AM
Re: rdtsc()
There are various ways to use the timer depending on what your want to accomplish, ranging from "run forever" with polling, to a timer tick interrupts, to anything in between.  The easiest is to just intialize it to run "forever" and then poll the current timer value.
Example one-time "run forever" initialization:
    #include "xparameters.h"
    #include "xtmrctr.h"
    XTmrCtr TimerCounter;
    Status = XTmrCtr_Initialize(&TimerCounter, XPAR_XPS_TIMER_0_DEVICE_ID);
    if (Status != XST_SUCCESS) {
        return XST_FAILURE;
     * Enable the Autoreload mode of the timer counters.
    XTmrCtr_SetOptions(&TimerCounter, 0, XTC_AUTO_RELOAD_OPTION);
     * Start the timer counter such that it's incrementing by default
    XTmrCtr_Start(&TimerCounter, XPAR_XPS_TIMER_0_DEVICE_ID);
Thereafter you can poll the present value like this (note that the 32 bit value will roll over):
    TheTime = XTmrCtr_GetValue(&TimerCounter,
-Brian
Re: rdtsc()
Brian,
  Thanks for the code examples. When I try to initialize the timer I get an XST_FAILURE.
//added a printline here
xil_printf("Timer Initialization Failure!\r\n");
        return XST_FAILURE;
I have an xps_timer in my design.  Do you know what I should check on to see why I'm getting this error?
thanks,
  crono
Message Edited by crono123 on 08-03-2009 01:47 PM
Re: rdtsc()
The comments for XTmrCtr_Initialize indicate it can return one of these three values:
*               - XST_SUCCESS if initialization was successful
*               - XST_DEVICE_IS_STARTED if the device has already been started
*               - XST_DEVICE_NOT_FOUND if the device doesn't exist
Id begin with that. Is XPAR_XPS_TIMER_0_DEVICE_ID correct in xparameters.h (have you tried regenerating the BSP from scratch?). Otherwise.... ?
Re: rdtsc()
The following code snippet shows that the timer device is already started.  I borrowed from your examples, thanks.   The program seems to stop at the line before the print statement "Fails here?".  I checked the xparameters.h file and the XPAR_XPS_TIMER_0_DEVICE_ID seems to refer to the correct timer instance.  (I only have one timer in my design).  I have not tried regenerating the BSP from scratch....will try now.
main()
   /* Initialize RS232_Uart - Set baudrate and number of stop bits */
   XUartNs550_SetBaud(XPAR_RS232_UART_BASEADDR, XPAR_XUARTNS550_CLOCK_HZ, 9600);
   XUartNs550_mSetLineControlReg(XPAR_RS232_UART_BASEADDR, XUN_LCR_8_DATA_BITS);
   print("-- Entering Accumulator Test Main() --\r\n");
   XTmrCtr xps_timer_0;
            XStatus Status;
   Xuint32 BeginTime;
            Xuint32 EndTime;
            Xuint32 Calibration;
            Xuint32 TimeRun;
            //Status = XTmrCtr_Initialize(&xps_timer_0, XPAR_XPS_TIMER_0_DEVICE_ID);
                 xil_printf("Timer Status Failure!\r\n");
        //return XST_FAILURE;
             if (Status == XST_DEVICE_IS_STARTED){
                        xil_printf("Timer is already started!\r\n");
             if(Status == XST_DEVICE_NOT_FOUND){
               xil_printf("Timer Device is not found!\r\n");
    XTmrCtr_SetOptions(&xps_timer_0, 0, XTC_AUTO_RELOAD_OPTION);
             xil_printf("Fails here?");
    XTmrCtr_Start(&xps_timer_0, XPAR_XPS_TIMER_0_DEVICE_ID);
