puneeth123
spi slave mode enable for zynq ultrascale + MPSOC
hi,
I am using zynq ultrascale + MPSOC. I want to enable my processor as spi slave mode. So how to enable it. By default it will be in master mode.
I am new to this. Please help.
savula
Hi @puneeth123 ,
Slave mode can be enabled in Software. In Vivado you just need to enable the SPI device and from software initialize the SPI as slave. Please check here for SPI slave mode examples: https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/spi/examples
Best Regards,
Srikanth
puneeth123
   Can we do it by using menuconfig.
