boltzman
swapb not working
So I have a miroblaze where I would like to easily swap data between big-endian and little-endian.
In IP Integrator I enabled the feature:
My code looks like this:
for ( i = 0 ; i < length ; i++ ){
    getfsl(payload[i], 0);
    payload[i] = mb_swapb(payload[i]);
For some reason though, I have been unable to make this work. I see how payload[i] has the "correct" value (inverted) before mb_swapb is executed, and then after that it is just zero...
I have tried all sorts of variatios, like:
    payload[i] = mb_swapb(&payload[i]);
Which for some reason, do "work", however payload[i] end up being the address of payload[i] byte reversed.... (as it should I guess, since I am passing the location of payload[i], instead of the value itself).
For me, that alone is prove that the instruction is implemented in hw and is working find, however for some reason when I actually pass it a value instead of a memory location I just get all zeros...
I have tried copiying payload[i] to a local variable and other modifications but still no luck...
Can somebody help with this?
Tags (2)
abhinayp
Hi @boltzman
This is a known issue in Vivado 2018.3 and 2019.1. It can only occur with area optimization when reorder instructions are enabled and pattern compare instructions are not enabled. So a simple workaround is to also enable pattern compare instructions (Enable Pattern Comparator on the General page of the MicroBlaze customization dialog).
It has been fixed in Vivado 2019.2.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
