using PS SPI_0 on Zynq in master mode, transfer a byte to PMOD port and check on logic analyser
          I am trying to send a signal to the PMOD port using functions in x.spips.h and x.spips.c with the zynq processor in MASTER MODE.I have enabled the SPI_0 port on Zynq processor and after implementing the design, assigned pins corresponding to PMOD port JA1. Now I want to send a byte to the MOSI line of SPI and check the value on oscilloscope or logic analyser. I have attached the image formats of block design and constraints file.
Thanks in advance....
Tags (4)
Re: using PS SPI_0 on Zynq in master mode, transfer a byte to PMOD port and check on logic analyser
Hi @krishnachandrasekhar100 ,
This looks good.
Were you able to achieve the results as expected over oscilloscope?
What is the issue you are encountering?
Praveen
Yes, I got the expected output after removing lines 10 and 11 in the constraints file(shown in image of previous post) and adding appropriate code in SDK.
The issue was that I could not observe the clock and data signals on the oscilloscope when I connected probe. After applying the changes, I could observe the signals.
Chandrasekhar D
