Participant n.horvat
AMM Slave Bridge - BSP Poblem
my custom IP core consist of two AXI4LITE Slave interfaces. In Vivado, after connecting them to the AXI master (eg. ZYNQ), they are both visible in Address Editor with assigned addresses.
In "system.hdf" file both of my slave peripherals are recognized, but after generation of BSP, only one axi peripheral is visible in "xparameters.h" file.
I can access both of them from cpu but there is no "BASEADDR" constant defined in "xparameters.h" file for second axi slave peripheral.
Is this known issue with Xilinx SDK (limitation?) or is there some kind of setting that need to be set while packing the IP core?
(I'm using Vivado 2018.2)
Thank you.
Re: AMM Slave Bridge - BSP Poblem
I have the same issue.
I have an AXI AMM bridge with one Avalon slave in my design. unable to find AXI AMM in system.mss & xparameter.h file.
did you find any solution??
My problem is with multiple AXI slave interfaces in one IP Core (only one AXI slave interface is recognized by SDK in my case).
