AXI Timer - PWM
does anybody has an working example for pwm output with an AXI Timer IP from Xilinx?
Xilinx doesn´t deliver any example in the SDK with that IP.
Thank you!
Re: AXI Timer - PWM
Ok it works now....
I was little bit confused of the defines for the TTC 1...solved it now :)
This is the working code for TTC 1:
#include "Xscugic.h"
#include "Xil_exception.h"
#include "xttcps.h"
#define TTC_DEVICE_ID	    XPAR_XTTCPS_0_DEVICE_ID
#define TTC_INTR_ID		    XPAR_XTTCPS_3_INTR
#define INTC_DEVICE_ID		XPAR_SCUGIC_SINGLE_DEVICE_ID
typedef struct {
	u32 OutputHz;
	u16 Interval;
	u8 Prescaler;
	u16 Options;
} TmrCntrSetup;
static TmrCntrSetup SettingsTable[1] = {
	{10, 0, 0, 0},
XScuGic Intc;
XTtcPs_Config *Config;
XTtcPs Timer;
TmrCntrSetup *TimerSetup;
static void SetupInterruptSystem(XScuGic *GicInstancePtr, XTtcPs *TtcPsInt);
static void TickHandler(void *CallBackRef);
int main()
	TimerSetup = &SettingsTable[TTC_DEVICE_ID];
	TimerSetup->Options |= (XTTCPS_OPTION_INTERVAL_MODE | XTTCPS_OPTION_WAVE_DISABLE);
	XTtcPs_Stop(&Timer);
 	Config = XTtcPs_LookupConfig(TTC_DEVICE_ID);
 	XTtcPs_CfgInitialize(&Timer, Config, Config->BaseAddress);
 	XTtcPs_SetOptions(&Timer, TimerSetup->Options);
 	XTtcPs_CalcIntervalFromFreq(&Timer, TimerSetup->OutputHz,&(TimerSetup->Interval), &(TimerSetup->Prescaler));
    XTtcPs_SetInterval(&Timer, TimerSetup->Interval);
    XTtcPs_SetPrescaler(&Timer, TimerSetup->Prescaler);
    SetupInterruptSystem(&Intc, &Timer);
     while(1){
     return 0;
		XScuGic_Config *IntcConfig;
		Xil_ExceptionInit();
		IntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
		XScuGic_CfgInitialize(GicInstancePtr, IntcConfig,
						IntcConfig->CpuBaseAddress);
		Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
					(Xil_ExceptionHandler)XScuGic_InterruptHandler,
					GicInstancePtr);
		XScuGic_Connect(GicInstancePtr, TTC_INTR_ID,
				(Xil_ExceptionHandler)TickHandler, (void *)TtcPsInt);
		XScuGic_Enable(GicInstancePtr, TTC_INTR_ID);
		XTtcPs_EnableInterrupts(TtcPsInt, XTTCPS_IXR_INTERVAL_MASK);
		XTtcPs_Start(TtcPsInt);
		Xil_ExceptionEnableMask(XIL_EXCEPTION_IRQ);
	u32 StatusEvent;
	StatusEvent = XTtcPs_GetInterruptStatus((XTtcPs *)CallBackRef);
	XTtcPs_ClearInterruptStatus((XTtcPs *)CallBackRef, StatusEvent);
	printf("Interrupt\n\r");
Scholar trenz-al
Re: AXI Timer - PWM
You are posting on Zynq forums, so I assume you use Zynq devices - you can as well use PS TTC PWM, its takes 20 minutes to get them running you have 3 PWM per TTC, as first TTC is used by Linux, you can use 3 PWM from the second one pretty freely.
just an option.
Re: AXI Timer - PWM
Hey,
sorry. Yes, I´m using a Zynq :)
I take a look at the PS PWM. Thanks for that tip!
Scholar trenz-al
Re: AXI Timer - PWM
i will ad the TTC support in Arduino lib, so then they will be available as "AnalogWrite"
but that will have to wait a few days.
its not that complicated connect LED
and play in debugger.. you see then when the PWM start to work
Re: AXI Timer - PWM
I have tried the TTC example from here with Timer 0:
http://forums.xilinx.com/t5/Xcell-Daily-Blog/Introduction-to-the-Zynq-Triple-Timer-Counter-Part-Three-Adam/ba-p/413105
This works fine. Now I want to change it to TImer 1, because I want use this PWM later in Linux and for that Timer 0 is blocked.
I changed the defines (see below) but nothing happens... :/
 * Copyright (c) 2009 Xilinx, Inc.  All rights reserved.
 * Xilinx, Inc.
 * XILINX IS PROVIDING THIS DESIGN, CODE, OR INFORMATION "AS IS" AS A
 * COURTESY TO YOU.  BY PROVIDING THIS DESIGN, CODE, OR INFORMATION AS
 * ONE POSSIBLE   IMPLEMENTATION OF THIS FEATURE, APPLICATION OR
 * STANDARD, XILINX IS MAKING NO REPRESENTATION THAT THIS IMPLEMENTATION
 * IS FREE FROM ANY CLAIMS OF INFRINGEMENT, AND YOU ARE RESPONSIBLE
 * FOR OBTAINING ANY RIGHTS YOU MAY REQUIRE FOR YOUR IMPLEMENTATION.
 * XILINX EXPRESSLY DISCLAIMS ANY WARRANTY WHATSOEVER WITH RESPECT TO
 * THE ADEQUACY OF THE IMPLEMENTATION, INCLUDING BUT NOT LIMITED TO
 * ANY WARRANTIES OR REPRESENTATIONS THAT THIS IMPLEMENTATION IS FREE
 * FROM CLAIMS OF INFRINGEMENT, IMPLIED WARRANTIES OF MERCHANTABILITY
 * AND FITNESS FOR A PARTICULAR PURPOSE.
 * helloworld.c: simple test application
#include <stdio.h>
#include "xttcps.h"
#define TTC_DEVICE_ID	    XPAR_XTTCPS_1_DEVICE_ID
typedef struct {
	u32 OutputHz;	/* Output frequency */
	u16 Interval;	/* Interval value */
	u8 Prescaler;	/* Prescaler value */
	u16 Options;	/* Option settings */
} TmrCntrSetup;
	{10, 0, 0, 0},	/* Ticker timer counter initial setup, only output freq */
static XScuGic Intc; //GIC
//XTtcPs *TtcPsInst;
int main()
	XTtcPs Timer;
	//Timer = &(TtcPsInst[TTC_DEVICE_ID]);
 	printf("\n\rAdam Edition MicroZed Using Vivado \n\r");
 	//initialise the timer
     while(1){
     return 0;
		XScuGic_Config *IntcConfig; //GIC config
		//initialise the GIC
	    //connect to the hardware
					GicInstancePtr);
		// Enable interrupts in the Processor.
	u32 StatusEvent;
	printf("event\n\r");
Re: AXI Timer - PWM
Ok it works now....
#include "xttcps.h"
typedef struct {
	u32 OutputHz;
	u16 Interval;
	u8 Prescaler;
	u16 Options;
} TmrCntrSetup;
	{10, 0, 0, 0},
XScuGic Intc;
XTtcPs Timer;
int main()
     while(1){
     return 0;
					GicInstancePtr);
	u32 StatusEvent;
