Participant sarit8
AXI4- explenation regarding transaction, data transfer, burst and beats
I'm little confused refarding the relationship between the above concept.
Does burst is just a type of AXI transaction> Can it take more the one clock transaction?
What is exactly a beat? does it contain address and data?
Re: AXI4- explenation regarding transaction, data transfer, burst and beats
A 'beat' is an individual data transfer within an AXI burst. If you are reading the spec you will see it says that burst length is the number of data transfers per burst, which they call beats. Each beat can be a number of bytes specified by burst size..An AXI 'burst' is a transaction in which multiple data items are transferred based upon a single address, and it is each data item transferred that is referred to as a 'beat'. Since there is only one address transfer, the addresses of each 'beat' in a burst are calculated based on the transaction type (INCR, FIXED or WRAP).
The AXI3 protocol allows up to 16 beats in any burst transaction, whereas the AXI4 protocol allows for up to 256 beats in an INCR type burst transaction.
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
