About AXI Interconnect Address Width Settings
I made the custom AXI peripherial IP to use in the Top Block design.
The problem's  custom IP  AXI Crossbar bus ( AXI_Interconnect ) has a width 31 bits meanwhile I need 32 bits ( desirable address 0x8100 0000 for example) according to the Top Block design Address Map.  Vivado doesn't allow to modify and save AXI Crossbar Adrress Width Value. Can you recommend?
回复: About AXI Interconnect Address Width Settings
Hi @olkhramus ,
Did you add this IP mannually?
It is suggested to add axi interconnect by vivado tool using Run Connection Automation.
Tool will auto-assign the address width.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
