About User IP Customization Parameter in Block Design
I made the own IP with the Customization Parameter ( for example Bus width) and going to make several IP instances in the Block Design  with the different Parameter values. The problem came : I can to make IP Upgrade after IP Packaging individually. It updates all IP Blocks the same Customization Parameter Value. Can you advise?
Re: About User IP Customization Parameter in Block Design
Hi @olkhramus
Could you give more details on how you set the parameters. Is it through the IP GUI or are you repackaging the IP each time?
repackaging the IP each time will not work as you are changing the revision for the IP and you can use only ne revision of an IP at the time. Adding GUI parameters is the correct way to design this
Florent
Hi @olkhramus
Florent
