Associate .elf not working in vivado 17.1
hi all,
here am facing problem creating download bit, with srec_spi_bootloader and bit file. loading the elf to vivado project and  associate the elf file to vivado design, then give run but it is not merging. previously i done same procedure 15.2 it is happen but in 17.1 getting problem, after adding elf file .bit size is decreasing. could u suggest me how to merge .elf and .bit i vivado 17.1
Scholar pratham
Re: Associate .elf not working in vivado 17.1
dilipg@vrindatech.com Try suggestion given in this thread
https://forums.xilinx.com/t5/Embedded-Development-Tools/Associate-elf-not-working/m-p/779739#M42346
-Pratham
hello pratham,
thnak u for quick response,  i will check and get back to u
Hi pratham,
we run those commands am getiing like these errors
set_property SCOPED_TO_CELLS { microblaze_0 } [get_files -all -of_objects [get_fileset E:/workspace/QDR_APP_RAMv2_2_2_110717/QDR_APP_RAMv2_2_2/project_1/project_1.runs] {E:/workspace/QDR_APP_RAMv2_2_2_110717/QDR_APP_RAMv2_2_2/project_1/project_1.sdk/srec/Debug/srec.elf}]
WARNING: [Vivado 12-1022] No filesets matching 'E:/workspace/QDR_APP_RAMv2_2_2_110717/QDR_APP_RAMv2_2_2/project_1/project_1.runs'
ERROR: [Common 17-161] Invalid option value '' specified for 'of_objects'.
Hi pratham,
set_property SCOPED_TO_CELLS { microblaze_0 } [get_files -all -of_objects [get_fileset E:/workspace/QDR_APP_RAMv2_2_2_110717/QDR_APP_RAMv2_2_2/project_1/project_1.srcs/] {E:/workspace/QDR_APP_RAMv2_2_2_110717/QDR_APP_RAMv2_2_2/project_1/project_1.sdk/srec/Debug/srec.elf}]
WARNING: [Vivado 12-1022] No filesets matching 'E:/workspace/QDR_APP_RAMv2_2_2_110717/QDR_APP_RAMv2_2_2/project_1/project_1.srcs/'
Since you are using windows, that path may be too long.
Try:
in a dos cmd window
  subst x: E:\workspace\QDR_APP_RAMv2_2_2_110717\QDR_APP_RAMv2_2_2
This will create a x: drive that kind of works like an alias
Now, open x:\project_1\project_1.xpr and change your scope to use x:/project_1/....
