Axi Dma S2mm interrupt problem
Hello all,
I am working on zc706 board, trying to save data stream data to the DDR memory as per the external trigger.
the block design is shown below, in this design, button_deb is the external trigger signal, based on that the data sample source Ip generate the data as shown in ILA image below. data stream contains 0x00000064 to 0x00000001 data.
now my requirement is that I should get interrupted after the data got saved in the memory location, but I am not getting that interrupt. please guide me on the sdk part of the code where am I doing wrong?
block_design.JPGblock design
data_saved.JPGsaved datadata_input.JPGinput data stream at the trigger
#include "xaxidma.h"
#include "xparameters.h"
#include "xil_exception.h"
#include "xdebug.h"
#ifndef DEBUG
extern void xil_printf(const char *format, ...);
#endif
 #include "xscugic.h"
#define DMA_DEV_ID		XPAR_AXIDMA_0_DEVICE_ID
#define MEM_BASE_ADDR		0x01000000
#define RX_INTR_ID		XPAR_FABRIC_AXI_DMA_0_S2MM_INTROUT_INTR
#define RX_BD_SPACE_BASE	(MEM_BASE_ADDR)
#define RX_BD_SPACE_HIGH	(MEM_BASE_ADDR + 0x0000FFFF)
#define RX_BUFFER_BASE		(MEM_BASE_ADDR + 0x00300000)
#define RX_BUFFER_HIGH		(MEM_BASE_ADDR + 0x004FFFFF)
#define INTC_DEVICE_ID          XPAR_SCUGIC_SINGLE_DEVICE_ID
#define RESET_TIMEOUT_COUNTER	10000
#define MAX_PKT_LEN		0x200
#define MARK_UNCACHEABLE        0x701
#define NUMBER_OF_BDS_PER_PKT		1
#define NUMBER_OF_PKTS_TO_TRANSFER 	1
#define NUMBER_OF_BDS_TO_TRANSFER	(NUMBER_OF_PKTS_TO_TRANSFER * \
						NUMBER_OF_BDS_PER_PKT)
#define COALESCING_COUNT		NUMBER_OF_PKTS_TO_TRANSFER
#define DELAY_TIMER_COUNT		100
 #define INTC		XScuGic
 #define INTC_HANDLER	XScuGic_InterruptHandler
static int CheckData(int Length, u32 StartValue);
//static void TxIntrHandler(void *Callback);
static void RxCallBack(XAxiDma_BdRing * RxRingPtr);
static void RxIntrHandler(void *Callback);
static int SetupIntrSystem(INTC * IntcInstancePtr, XAxiDma * AxiDmaPtr,  u16 RxIntrId);
static void DisableIntrSystem(INTC * IntcInstancePtr,u16 RxIntrId);
static int RxSetup(XAxiDma * AxiDmaInstPtr);
XAxiDma AxiDma;
static INTC Intc;	/* Instance of the Interrupt Controller */
volatile int TxDone;
volatile int RxDone;
volatile int Error;
int main(void)
	int Status;
	XAxiDma_Config *Config;
	/* Initial setup for Uart16550 */
	xil_printf("\r\n--- Entering main() --- \r\n");
	Config = XAxiDma_LookupConfig(DMA_DEV_ID);
	if (!Config) {
		xil_printf("No config found for %d\r\n", DMA_DEV_ID);
		return XST_FAILURE;
	/* Initialize DMA engine */
	XAxiDma_CfgInitialize(&AxiDma, Config);
	if(!XAxiDma_HasSg(&AxiDma)) {
		xil_printf("Device configured as Simple mode \r\n");
		return XST_FAILURE;
	Status = RxSetup(&AxiDma);
	if (Status != XST_SUCCESS) {
		xil_printf("Failed RX setup\r\n");
		return XST_FAILURE;
	/* Set up Interrupt system  */
	Status = SetupIntrSystem(&Intc, &AxiDma,  RX_INTR_ID);
		xil_printf("Failed intr setup\r\n");
		return XST_FAILURE;
	/* Initialize flags before start transfer test  */
	TxDone = 0;
	RxDone = 0;
	Error = 0;
	 * Wait TX done and RX done
	while (((RxDone < NUMBER_OF_BDS_TO_TRANSFER)) && !Error) {
		/* NOP */
	if (Error) {
		xil_printf("Failed test transmit%s done, "
			"receive%s done\r\n", TxDone? "":" not",
					RxDone? "":" not");
		goto Done;
	}else {
		 * Test finished, check data
		Status = CheckData(MAX_PKT_LEN * NUMBER_OF_BDS_TO_TRANSFER,
									0x64);
			xil_printf("Data check failed\r\n");
			goto Done;
		xil_printf("Successfully ran AXI DMA SG interrupt Example\r\n");
	/* Disable TX and RX Ring interrupts and return success */
	DisableIntrSystem(&Intc,  RX_INTR_ID);
Done:
	xil_printf("--- Exiting main() --- \r\n");
		return XST_FAILURE;
	return XST_SUCCESS;
* This function checks data buffer after the DMA transfer is finished.
* We use the static tx/rx buffers.
* @param	Length is the length to check
* @param	StartValue is the starting value of the first byte
* @return	- XST_SUCCESS if validation is successful
*		- XST_FAILURE if validation fails.
* @note		None.
	u32 *RxPacket;
	int Index = 0;
	u32 Value;
	RxPacket = (u32 *) RX_BUFFER_BASE;
	Value = StartValue;
	for(Index = 0; Index < Length; Index++) {
		if (RxPacket[Index] != Value) {
			xil_printf("Data error %d: %x/%x\r\n",
			    Index, RxPacket[Index], Value);
			return XST_FAILURE;
		Value = (Value + 1) & 0xFF;
	return XST_SUCCESS;
* This is the DMA RX callback function called by the RX interrupt handler.
* This function handles finished BDs by hardware, attaches new buffers to those
* BDs, and give them back to hardware to receive more incoming packets
* @param	RxRingPtr is a pointer to RX channel of the DMA engine.
* @return	None.
* @note		None.
	int BdCount;
	XAxiDma_Bd *BdPtr;
	XAxiDma_Bd *BdCurPtr;
	u32 BdSts;
	int Index;
	/* Get finished BDs from hardware */
	BdCount = XAxiDma_BdRingFromHw(RxRingPtr, XAXIDMA_ALL_BDS, &BdPtr);
	BdCurPtr = BdPtr;
	for (Index = 0; Index < BdCount; Index++) {
		 * Check the flags set by the hardware for status
		 * If error happens, processing stops, because the DMA engine
		 * is halted after this BD.
		BdSts = XAxiDma_BdGetSts(BdCurPtr);
		if ((BdSts & XAXIDMA_BD_STS_ALL_ERR_MASK) ||
		    (!(BdSts & XAXIDMA_BD_STS_COMPLETE_MASK))) {
			Error = 1;
			break;
		/* Find the next processed BD */
		BdCurPtr = (XAxiDma_Bd *)XAxiDma_BdRingNext(RxRingPtr, BdCurPtr);
		RxDone += 1;
* This is the DMA RX interrupt handler function
* It gets the interrupt status from the hardware, acknowledges it, and if any
* error happens, it resets the hardware. Otherwise, if a completion interrupt
* presents, then it calls the callback function.
* @param	Callback is a pointer to RX channel of the DMA engine.
* @return	None.
* @note		None.
	XAxiDma_BdRing *RxRingPtr = (XAxiDma_BdRing *) Callback;
	u32 IrqStatus;
	int TimeOut;
	/* Read pending interrupts */
	IrqStatus = XAxiDma_BdRingGetIrq(RxRingPtr);
	/* Acknowledge pending interrupts */
	XAxiDma_BdRingAckIrq(RxRingPtr, IrqStatus);
	 * If no interrupt is asserted, we do not do anything
	if (!(IrqStatus & XAXIDMA_IRQ_ALL_MASK)) {
		return;
	 * If error interrupt is asserted, raise error flag, reset the
	 * hardware to recover from the error, and return with no further
	 * processing.
	if ((IrqStatus & XAXIDMA_IRQ_ERROR_MASK)) {
		XAxiDma_BdRingDumpRegs(RxRingPtr);
		Error = 1;
		/* Reset could fail and hang
		 * NEED a way to handle this or do not call it??
		XAxiDma_Reset(&AxiDma);
		TimeOut = RESET_TIMEOUT_COUNTER;
		while (TimeOut) {
			if(XAxiDma_ResetIsDone(&AxiDma)) {
				break;
			TimeOut -= 1;
		return;
	 * If completion interrupt is asserted, call RX call back function
	 * to handle the processed BDs and then raise the according flag.
	if ((IrqStatus & (XAXIDMA_IRQ_DELAY_MASK | XAXIDMA_IRQ_IOC_MASK))) {
		RxCallBack(RxRingPtr);
* This function setups the interrupt system so interrupts can occur for the
* DMA, it assumes INTC component exists in the hardware system.
* @param	IntcInstancePtr is a pointer to the instance of the INTC.
* @param	AxiDmaPtr is a pointer to the instance of the DMA engine
* @param	TxIntrId is the TX channel Interrupt ID.
* @param	RxIntrId is the RX channel Interrupt ID.
* @return
*		- XST_SUCCESS if successful,
*		- XST_FAILURE.if not succesful
* @note		None.
	XAxiDma_BdRing *RxRingPtr = XAxiDma_GetRxRing(AxiDmaPtr);
	int Status;
	XScuGic_Config *IntcConfig;
	 * Initialize the interrupt controller driver so that it is ready to
	 * use.
	IntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
	if (NULL == IntcConfig) {
		return XST_FAILURE;
	Status = XScuGic_CfgInitialize(IntcInstancePtr, IntcConfig,
					IntcConfig->CpuBaseAddress);
		return XST_FAILURE;
	XScuGic_SetPriorityTriggerType(IntcInstancePtr, RxIntrId, 0xA0, 0x3);
	Status = XScuGic_Connect(IntcInstancePtr, RxIntrId,
				(Xil_InterruptHandler)RxIntrHandler,
				RxRingPtr);
		return Status;
//	XScuGic_Enable(IntcInstancePtr, TxIntrId);
	XScuGic_Enable(IntcInstancePtr, RxIntrId);
	/* Enable interrupts from the hardware */
	Xil_ExceptionInit();
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
			(Xil_ExceptionHandler)INTC_HANDLER,
			(void *)IntcInstancePtr);
	Xil_ExceptionEnable();
	return XST_SUCCESS;
* This function disables the interrupts for DMA engine.
* @param	IntcInstancePtr is the pointer to the INTC component instance
* @param	TxIntrId is interrupt ID associated w/ DMA TX channel
* @param	RxIntrId is interrupt ID associated w/ DMA RX channel
* @return	None.
* @note		None.
static void DisableIntrSystem(INTC * IntcInstancePtr, u16 RxIntrId)
//	XScuGic_Disconnect(IntcInstancePtr, TxIntrId);
	XScuGic_Disconnect(IntcInstancePtr, RxIntrId);
* This function sets up RX channel of the DMA engine to be ready for packet
* reception
* @param	AxiDmaInstPtr is the pointer to the instance of the DMA engine.
* @return	- XST_SUCCESS if the setup is successful.
*		- XST_FAILURE if fails.
* @note		None.
	XAxiDma_BdRing *RxRingPtr;
	int Status;
	XAxiDma_Bd BdTemplate;
	XAxiDma_Bd *BdPtr;
	int BdCount;
	int FreeBdCount;
	UINTPTR RxBufferPtr;
	int Index;
	RxRingPtr = XAxiDma_GetRxRing(&AxiDma);
	/* Disable all RX interrupts before RxBD space setup */
	XAxiDma_BdRingIntDisable(RxRingPtr, XAXIDMA_IRQ_ALL_MASK);
	/* Setup Rx BD space */
	BdCount = XAxiDma_BdRingCntCalc(XAXIDMA_BD_MINIMUM_ALIGNMENT,
				RX_BD_SPACE_HIGH - RX_BD_SPACE_BASE + 1);
	Status = XAxiDma_BdRingCreate(RxRingPtr, RX_BD_SPACE_BASE,
					RX_BD_SPACE_BASE,
					XAXIDMA_BD_MINIMUM_ALIGNMENT, BdCount);
		xil_printf("Rx bd create failed with %d\r\n", Status);
		return XST_FAILURE;
	 * Setup a BD template for the Rx channel. Then copy it to every RX BD.
	XAxiDma_BdClear(&BdTemplate);
	Status = XAxiDma_BdRingClone(RxRingPtr, &BdTemplate);
		xil_printf("Rx bd clone failed with %d\r\n", Status);
		return XST_FAILURE;
	/* Attach buffers to RxBD ring so we are ready to receive packets */
	FreeBdCount = XAxiDma_BdRingGetFreeCnt(RxRingPtr);
	Status = XAxiDma_BdRingAlloc(RxRingPtr, FreeBdCount, &BdPtr);
		xil_printf("Rx bd alloc failed with %d\r\n", Status);
		return XST_FAILURE;
	BdCurPtr = BdPtr;
	RxBufferPtr = RX_BUFFER_BASE;
	for (Index = 0; Index < FreeBdCount; Index++) {
		Status = XAxiDma_BdSetBufAddr(BdCurPtr, RxBufferPtr);
			xil_printf("Rx set buffer addr %x on BD %x failed %d\r\n",
			(unsigned int)RxBufferPtr,
			(UINTPTR)BdCurPtr, Status);
			return XST_FAILURE;
		Status = XAxiDma_BdSetLength(BdCurPtr, MAX_PKT_LEN,
					RxRingPtr->MaxTransferLen);
			xil_printf("Rx set length %d on BD %x failed %d\r\n",
			    MAX_PKT_LEN, (UINTPTR)BdCurPtr, Status);
			return XST_FAILURE;
		/* Receive BDs do not need to set anything for the control
		 * The hardware will set the SOF/EOF bits per stream status
		XAxiDma_BdSetCtrl(BdCurPtr, 0);
		XAxiDma_BdSetId(BdCurPtr, RxBufferPtr);
		RxBufferPtr += MAX_PKT_LEN;
	 * Set the coalescing threshold, so only one receive interrupt
	 * occurs for this example
	 * If you would like to have multiple interrupts to happen, change
	 * the COALESCING_COUNT to be a smaller value
	Status = XAxiDma_BdRingSetCoalesce(RxRingPtr, COALESCING_COUNT,
			DELAY_TIMER_COUNT);
		xil_printf("Rx set coalesce failed with %d\r\n", Status);
		return XST_FAILURE;
	Status = XAxiDma_BdRingToHw(RxRingPtr, FreeBdCount, BdPtr);
		xil_printf("Rx ToHw failed with %d\r\n", Status);
		return XST_FAILURE;
	/* Enable all RX interrupts */
	XAxiDma_BdRingIntEnable(RxRingPtr, XAXIDMA_IRQ_ALL_MASK);
	/* Start RX DMA channel */
	Status = XAxiDma_BdRingStart(RxRingPtr);
		xil_printf("Rx start BD ring failed with %d\r\n", Status);
		return XST_FAILURE;
	return XST_SUCCESS;
I want to use an interrupt to repeatedly save the input data stream as per the external trigger. please guide me on this.
regards,
Amit
Re: Axi Dma S2mm interrupt problem
hello @calebd ,
sorry for the very late reply!
I found the solution, the problem was with the T_Last signal of my custom IP, the T_last signal was high after the T_valid signal goes low, after some correction in my custom IP code now the interrupt is occurring after the data transfer done.
In my design, I have to save 64 bit of stream data at the same DDR location, after every external trigger.
now the data transfer is happening properly as per my requirement, for first data transfer, but at every interrupts instance data transfer data is saved at a different location. I want to save data at the same location, please suggest me a solution for this.
#include "xdebug.h"
#include "xgpio.h"
#include"xil_io.h"
#ifndef DEBUG
#endif
#define GPIO_EXAMPLE_DEVICE_ID  XPAR_GPIO_0_DEVICE_ID
#define RX_BUFFER_BASE		(MEM_BASE_ADDR + 0x00200000)
#define RX_BUFFER_HIGH		(MEM_BASE_ADDR + 0x004FFfFF)
#define packet_length 0x1400
#define MAX_PKT_LEN 0xa000
XGpio Gpio;
static int print_data(int length);
XAxiDma AxiDma;
volatile int Error;
int main(void)
	int Status;
	int Status1 = XGpio_Initialize(&Gpio, GPIO_EXAMPLE_DEVICE_ID);
		if (Status1 != XST_SUCCESS) {
			return XST_FAILURE;
	XGpio_SetDataDirection(&Gpio, 1, 0x0000);
	XGpio_DiscreteWrite(&Gpio, 1, packet_length );
	if (!Config) {
		return XST_FAILURE;
		return XST_FAILURE;
		return XST_FAILURE;
while(1){
		return XST_FAILURE;
	RxDone = 0;
	 * Wait  RX done
	while (RxDone < NUMBER_OF_BDS_TO_TRANSFER)
		/* NOP */
	xil_printf("Data transfer done\r\n");
		Status = print_data(MAX_PKT_LEN/4);
			xil_printf("Data print not done\r\n");
			goto Done;
Done:
		return XST_FAILURE;
	return XST_SUCCESS;
	u32 *RxPacket;
	int Index = 0;
	for(Index = 0; Index < length; Index++) {
		xil_printf("Data[%d] : %x \n\r", Index,  RxPacket[Index]);
	return XST_SUCCESS;
	int BdCount;
	XAxiDma_Bd *BdPtr;
	u32 BdSts;
	int Index;
	BdCurPtr = BdPtr;
			Error = 1;
			break;
		RxDone += 1;
	u32 IrqStatus;
	int TimeOut;
		return;
	 * processing.
		Error = 1;
		while (TimeOut) {
				break;
			TimeOut -= 1;
		return;
	int Status;
	 * use.
		return XST_FAILURE;
		return XST_FAILURE;
				RxRingPtr);
		return Status;
	return XST_SUCCESS;
	int Status;
	XAxiDma_Bd *BdPtr;
	int BdCount;
	int FreeBdCount;
	int Index;
					RX_BD_SPACE_BASE,
		return XST_FAILURE;
		return XST_FAILURE;
		return XST_FAILURE;
	BdCurPtr = BdPtr;
			return XST_FAILURE;
			return XST_FAILURE;
			DELAY_TIMER_COUNT);
		return XST_FAILURE;
		return XST_FAILURE;
		return XST_FAILURE;
	return XST_SUCCESS;
Hello @amitlwaghmare,
This looks like the example code for Scatter Gather with interrupts.  Do you see all the printouts of the normal example ("entering main" "AXI DMA Scatter Gather Example Completed" and "exiting main")?
I noticed you are using the CheckData function which does the same math as the original transmitted data.  Since your data won't look exactly the same (unless you set your custom IP that way) then this function should fail.
The data you are seeing in memory does not show values "4", "3", "2", or "1" so does your ILA show those values are being streamed out?  Potentially the data stream isn't completing properly so not sending out an interrupt?  Could I get a copy of your ILA trace?
PG021 (AXI DMA Product Guide) page 30 talks about the IRQThresholdSts bits which would show how close the DMA is to sending out an interrupt.  Can you look at that register (S2MM_DMASR) for what the IRQThresholdSts bits are when your data is done streaming (should be 0 at that point)?
Finally, I notice your interrupts are being concatenated before sent to the PS.  Is your software reading for the right interrupt (DMA not GPIO) in your system?
Caleb
Caleb
hello @calebd ,
#include "xdebug.h"
#include "xgpio.h"
#include"xil_io.h"
#ifndef DEBUG
#endif
XGpio Gpio;
XAxiDma AxiDma;
volatile int Error;
int main(void)
	int Status;
			return XST_FAILURE;
	if (!Config) {
		return XST_FAILURE;
		return XST_FAILURE;
		return XST_FAILURE;
while(1){
		return XST_FAILURE;
	RxDone = 0;
	 * Wait  RX done
		/* NOP */
			goto Done;
Done:
		return XST_FAILURE;
	return XST_SUCCESS;
	u32 *RxPacket;
	int Index = 0;
	return XST_SUCCESS;
	int BdCount;
	XAxiDma_Bd *BdPtr;
	u32 BdSts;
	int Index;
	BdCurPtr = BdPtr;
			Error = 1;
			break;
		RxDone += 1;
	u32 IrqStatus;
	int TimeOut;
		return;
	 * processing.
		Error = 1;
		while (TimeOut) {
				break;
			TimeOut -= 1;
		return;
	int Status;
	 * use.
		return XST_FAILURE;
		return XST_FAILURE;
				RxRingPtr);
		return Status;
	return XST_SUCCESS;
	int Status;
	XAxiDma_Bd *BdPtr;
	int BdCount;
	int FreeBdCount;
	int Index;
					RX_BD_SPACE_BASE,
		return XST_FAILURE;
		return XST_FAILURE;
		return XST_FAILURE;
	BdCurPtr = BdPtr;
			return XST_FAILURE;
			return XST_FAILURE;
			DELAY_TIMER_COUNT);
		return XST_FAILURE;
		return XST_FAILURE;
		return XST_FAILURE;
	return XST_SUCCESS;
Thank you for replying back with what fixed your issue.  For reference TLAST must only be asserted at the end of a transfer of data, and only for that last data transfer (good practice would be to have 1 clock cycle of TLAST when the end of transfer is complete and equal to TVALID for that last beat of data).
Caleb
Caleb
