Bad performance of 10G MAC on ZCU102
I tested 10G Ethernet on ZCU102 following XAPP1305. But the performance is very bad. None of TX and RX data rate can achieve more than 1Gpbs. Does someone try this? What's the performance can be achieved?
Thank you.
Re: Bad performance of 10G MAC on ZCU102
Hi, Sophiewesvrus,
You could check our test performance of XAPP1305 in below link:
http://www.wiki.xilinx.com/Zynq+mp+Ethernet+Performance+2016.4
And You could check how we setup our hardward and detailed steps to build a project from below links:
http://www.wiki.xilinx.com/PS+and+PL+based+Ethernet+in+Zynq+MPSoC
http://www.wiki.xilinx.com/Performance+tests+procedure+and+results+with+LWIP
Hope this helps.
-Longley
Voyager
Voyager
Hey @sophiewusvrus,
What is a Gpbs?
  • 1 Gigabyte per second would be kind of expected on 10G
  • 1 Gigabit per second would be a little low and suggest severe congestion
If you can only achieve 1Gbit/s it would help to see the 'on wire' data.
Best,
Herbert
-------------- Yes, I do this for fun!
Hi, Sophiewesvrus,
Hope this helps.
-Longley
@sophiewusvrus
Which Vivado/Petalinux tools did you test the XAPP1305 with?
I verified that I can match the Xilinx posted numbers of ~4-5 Gbitps with the 2016.4 files when connecting two different ZCU102 boards together.
However the performance drops to ~250 Mbitps over TCP when I test the same migrated design with the 2017.1 or 2017.2 tools.
I am also seeing kernel panics when testing with mtu=9000 on the 2017.1 and 2017.2 designs that I did not see with the 2016.4 design. I posted a thread about that here:
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2017-2-Kernel-panic-in-quot-skb-copy-and-csum-dev-quot/m-p/798458
Has anyone verified the 10G speed with the 2017.1 and 2017.2 tools?
Adam
This is what I get with 2017.1 ready-to-test solution fro 1500 MTU. I do not get any kernel panics. Everything works well but the performance is pathetic. Were you able to find a way to improve the performance?
TCP TX:          161 Mbits/sec
TCP RX:   1.11 Gbits/sec
UDP TX:   1.62 Gbits/sec (With lot of Errors)
UDP RX:   355 Mbits/sec
@dsingh
Yes, I was able to get performance up to ~4Gbps. Check out the thread below for details.
https://forums.xilinx.com/t5/Networking-and-Connectivity/Is-there-petalinux-2017-2-support-for-10G-Ethernet-Subsystem-v2/m-p/817702#M11774
We saw that we had ~2Gbps per stream and decided to parallelize the streams to see what the max throughput was.
In order to just get to the 2Gbps per single stream though, we had to change the FIFO size in the Vivado project and change one of the DMA properties in the petalinux device tree as described in some of my earlier posts.
Thanks Adam!!
