Visitor steve77
Best way to interface with AXI Stream core
OK so I dont  want to use Zynq or some other embedded processor - and want to use an IP core that has AXI streaming interface.
I need a something that will
TRANSMIT:) pull data out of a NATIVE fifo or dual part memory and convert it to streaming master
RECEIVE:) take a axi stream slave and pump it into a NATIVE fifo or dual part memory so i can read out of NATIVE interface
there has got to be a simple way to do this -
I looked at  the following :
1)  [custom logic that moves my data to/from axi_lite] => [axi streaming fifo core  ]  (stream)
2)  [custom logic that moves my data to/from axi_lite] => [axi  data mover core ]   (stream)
If the silly cores weren't encrypted it would be a snap to snip away all the AXI crap and drive the interface directy.
Re: Best way to interface with AXI Stream core
HI @steve77,
If you want a template for IPs with AXI interfaces, create a new IP in vivado:
1. Tool > Create and package a new IP
2. Select create new AXI4 peripheral
3. Add the required interface (for example AXI-Lite master)
4. edit the IP
-> This will create a template you can use for an AXI interface (full/lite or stream)
Hope that helps,
Florent
Florent
