Visitor mx_muc
BootROM Header Search after soft reboot
Hello!
I have a problem with the BootROM Header Search after a soft reboot (Petalinux: reboot).
I have bootloader images (FSBL+FPGA+U-Boot) stored at a QSPI-Flash. Linux Images are on a SD-Card / eMMC-Chip.
Let's say i start the system with a bootloader image stored at adress 0x800000. Consequently the BootROM Header of this image starts also at 0x800000. When i start the system my bootloader is found and executed. Afterwards U-Boot starts my linux.
When I flash now another bootloader image to adress 0x0 of the QSPI from my linux system, BootROM should find this new bootloader, because BootROM Header Search starts at 0x0 and increments with 32 KiB to find an image. When i reboot the system with a linux command, the system restarts, but the old bootloader is used.
When i power off the system and power it on again the new bootloader is used.
How can i reset the system from linux, that in this way the new bootloader also is used.
Best regards!
Community Manager
Community Manager
Re: BootROM Header Search after soft reboot
What you are trying to do is multiboot. You should update multiboot register before soft reset so that when you reset the system, it gets booted from the address specified in Multiboot register. Please refer to http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Multiboot+Tech+Tip for more details.
Community Manager
Community Manager
Visitor mx_muc
Thank you!
That was exactly the solution.
To solve the problem run the following command before restarting:
petalinux:~# poke 0xF800702C 0x0
petalinux:~# shutdown -r now
0xF800702C  is the MULTIBOOT_ADDR
