Visitor areslee
Can I generate chip select signal myself when I using SPI master manual ss mode on ZYNQ
I means don't use PS ss[0..2], I generate slave signal myself using PS's GPIOs, so I can have many ss signals to control many slaves
Scholar jg_bds
Re: Can I generate chip select signal myself when I using SPI master manual ss mode on ZYNQ
If you only intend to use the controller in Master I/O mode AND manual slave select mode, I can't see why not. That arrangement will foreclose on the ability to use automatic SS mode, though.
For the sake of flexibility, you might want to use EMIO for the SPI signals and all of your chip selects (EMIO GPIO). That way, you can combine them using logic in the PL and retain the possibility of using automatic SS mode. (This suggestion assumes your SPI speeds aren't so fast that they preclude using EMIO.)
-Joe G.
Scholar jg_bds
-Joe G.
Visitor areslee
Thank you for replay, I will try it.
