Observer @bucky
Cortex-A9 IRQ with priority over configMAX_API_CALL_INTERRUPT_PRIORITY / Motor Control
Hi guys,
I'm using a Xilinx ZYNQ device equipped with the help of FreeRTOS port.
The final application will be used in the context of electric motor control so, in order to reduce control-law interrupt latency, I've registered the related handler with a priority that exceeds configMAX_API_CALL_INTERRUPT_PRIORITY.
Given the previous settings, the interrupt is properly triggered also under FreeRTOS critical sections - exactly as I expected to.
Now, I intend to share data between application tasks and the aforementioned interrupt handler.
To avoid race condition I intend to mask cpu interrupts, write the data, and then re-enable cpu interrupts.
Something like in the example reported below.
Is this possible /is there a better way to do it?
Does it interfere with FreeRTOS itself leading to system failure?
static uint32_t EM_PositionReferece = 0u;
/* run in the context of the task */
void EM_SetPositionReference(UINT32 user)
/* mask CPU interrupt */
__asm volatile ( "CPSID i");
__asm volatile ( "DSB" );
__asm volatile ( "ISB" );
/* set motor-control position reference to be used in interrupt */
EM_PositionReferece = user;
* NO FreeRTOS API usage here!
/* un-mask CPU interrupt */
__asm volatile ( "CPSIE i");
void PL_IRQHandler(void)
ControlLaw_Exec(EM_PositionReferece );
As last thing, in the previous example the interrupt are fully masked and then unmasked.
Is there a way (e.g. a dedicated CPU instruction) to get interrupt masking status and simultaneously disabling them?
What I want to achieve is something like the line below
/* mask interrupt and get previous masking status */
irqMask = _MaskIRQ();
* set motor-control variable shared with IRQ
/* restore interrupt masking status read at _MaskIRQ */
_RestoreIRQ(irqMask);
Thanks in advance,
Bucky
Observer richardbarry
Re: Cortex-A9 IRQ with priority over configMAX_API_CALL_INTERRUPT_PRIORITY / Motor Control
Replied here https://sourceforge.net/p/freertos/discussion/382005/thread/4e4767a000/
Richard.
+ http://www.FreeRTOS.org
The de facto standard, downloaded every 4.2 minutes during 2015.
+ http://www.FreeRTOS.org/plus
IoT, Trace, Certification, TCP/IP, FAT FS, Training, and more...
