Deassert axi dma interrupt over axi lite interface
I have a design in vivado 2018.2 that uses the axi dma 7.1. The dma is in direct mode and I am only using the s2mm channel. I am programming the dma in a FSM and in simulation, I am seeing the dma transfers take place. I have the interrupt on complete enabled and I am also seeing the interrupt pin; s2mm_introut; assert at the end of the trasfer.
I am however, unable to deassert/clear this interrupt over the axi lite interface. I have tried to disable the interrupt upon transfer complete in the s2mm_dmacr, and the pin goes low. But when I enable the interrupt again for the next transfer, the interrupt pin immediately goes high. Writing a 1 to the interrupt on complete bit in the s2mm_dmasr does not affect the pin. Any help on how to acheive this is appreciated
Re: Deassert axi dma interrupt over axi lite interface
"Writing a 1 to the interrupt on complete bit in the s2mm_dmasr does not affect the pin" this is incorrect. My axi lite transfer that did this was not finishing successfully. I fixed that, and it works now.
