Debugger Terminates Prematurely in using Microblaze in 64-bit mode
Currently, I'm using a 32-bit Microblaze in my design with Extended Addressing enabled. I want to use a 64-bit Microblaze so I can use 64-bit address pointers directly; however, when I start the debug session in the SDK the GDB debugger terminates immediately. I'm using Vivado 2018.3.
Thanks in advance,
ww
Re: Debugger Terminates Prematurely in using Microblaze in 64-bit mode
Hi @winefred ,
Could you please give detail of termination from SDK log file?
Praveen
Hi Praveen,
I only see the terminate message from the XSCT console inside of the SDK IDE. Is there another log file outside of the SDK IDE that might provide more details?
Winefred
