I build the example microblaze with AXI support which synthesized, implemented and built the bit stream. I exported the hardware and luanched the SDK. I created some of the examples for the gpio. I was able to get 3 of the four examples working. I recieved a compile error in the xgpoi_intr_tapp_example.c example.
'XPAR_INTC_0_GPIO_0_VEC_ID' undeclared (first use in this function)
xgpio_intr_tapp_example.c
/helloworld_bsp_xgpio_intr_tapp_example_1/src
line 93 C/C++ Problem
It's failing on the define of INTC_GPIO_INTERRUPT_ID:
#ifdef XPAR_INTC_0_DEVICE_ID
#define INTC_GPIO_INTERRUPT_IDXPAR_INTC_0_GPIO_0_VEC_ID
#define INTC_DEVICE_ID XPAR_INTC_0_DEVICE_ID
#else
#define INTC_GPIO_INTERRUPT_ID XPAR_FABRIC_AXI_GPIO_0_IP2INTC_IRPT_INTR
#define INTC_DEVICE_ID XPAR_SCUGIC_SINGLE_DEVICE_ID
#endif /* XPAR_INTC_0_DEVICE_ID */
Given that this an example, I figured that there is something wrong in the steps leading up to this.
I did a search of the forums for: xgpoi_intr_tapp_example nad XPAR_INTC_0_GPIO_0_VEC_ID and came up with a few results but not related to my problem.
