Failed to load shared libraries
I am having trouble creating custom applications for my zynq chip running petalinux.  First of all, I am not using the petalinux tools, as I have a complicated device tree.
I am able to compile my application on my host machine, then when I move it over to my board to be run, I get the following error:
error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
What am I missing?  How do I get libstdc++ to my ramdisk?
Re: Failed to load shared libraries
Go to where your toolchain is installed, in my case its
/opt/Xilinx/SDK/2015.4/gnu/arm/lin
then run the following
find . -name libstdc*
./arm-xilinx-linux-gnueabi/libc/usr/lib/libstdc++.so.6
./arm-xilinx-linux-gnueabi/libc/usr/lib/libstdc++.so.6.0.20
./arm-xilinx-linux-gnueabi/libc/usr/lib/libstdc++.a
I copied the shared library and created the links(some of those are links) into my ramdisk directory and then repack my ramdisk
Also, I build everything with a script that I wrote so if you use petalinux I can't tell you how to fix that but this info should point you in the right direction.
jeff
Not sure what release you are using but libstdc++ was not in the prebuilt ramdisk for 2015.4.  I just pulled it in from the toolchain install and then repacked the ramdisk.  Of if you are just trying to test something, you can just scp it onto the system.
jeff.
Thanks for the info.  I am a bit of a novice, can you explain what you mean by pulled it in from the toolchain?
jeff
Thanks for the help. This worked!
-Matt
