GMII to RGMII with DMA
Hi All,
I am using a GMII - RGMII block in my design and I am interested in getting access to the received Ethernet data on PS. I would like to know if there is any way to get access to the data on PS. Also, are there any reference designs available on connecting DMA with GMII-RGMII block.
Re: GMII to RGMII with DMA
You are unlikely to find a reference design that does that, for the simple reason that most people wouldn't want to DMA the raw PCS-level data.  Instead, most designs will use an Ethernet MAC to process the PCS-level data, and DMA the results of that.
Assuming that's actually what you want to do (and that you have a Zynq), you have the option of using either a MAC IP core in the PL, or one of the MACs in the PS (which can be accessed via EMIO).
Thanks for the reply. Could you let me know if I can use AXI Ethernet block (AXI 1G/2.5G Ethernet Subsystem IP) and connect it to DMA using FIFO  (similar to how the ethernet works within PS).
Thank you.
Participant fincs
The output of the AXI Ethernet is an interface axi-stream. The core input axi-dma is an interface axi-stream. Therefore, they can be connected to each other.
