05-07-2019 11:11 AM
Dear Forum,
I’ve built a micro blaze system with axi-timer ip in place and connected the pwm output to one of the pmod connectors on my Arty S7 board. The Vivado project compiles so I’ve moved to the xsdk and generated a test SW project using one of the supplied templates. This also runs, but I cannot observe any signal change on the pmod pin.
My next move is to look at the pwm output in chipscope, but can anyone point me to a similar design that I can use as an example? In particular any simple C code to setup the AXI-Timer is for pwm operation.
ttfn,
dje666
05-08-2019 05:28 AM
Dear Forum,
Having rebuilt the Microblaze design from scratch I am now getting PWM output as expected.
I can't describe what I've dont differently, but all the default build processes have worked and I have PWM output on my scope.
Dje666
05-08-2019 03:51 AM
Dear Forum,
The Mystery deepens.
1) Simple Zynq design on MiniZed with Axi-Timer IP results in the generation of PWM output observed on a scope, and a series of messages on the xSDK terminal stating which of the four PWM output settings the system is currenlty processing.
2) The "same" deisgn built using a MicroBlaze processor results in the four messages being printed to the console in rapid succession and no output on the PWM pin. I am trying to understand why the Microblaze design is running through the SW with out pausing to generate the PWM output.
Is this an interrupt issue?
Any ideas greatfully recieved.
TTFN,.
DJE666
05-08-2019 05:28 AM
Dear Forum,
Dje666
