How do I verify that my MIO is assigned to a certain package pin?
I am using Vivado 2019.1 and a Zynq Ultrascale+ SoC.
How can I verify that a given MIO is routed to a specific package pin?
  • In the PS recustomization screen, you can assign peripherals to ranges of MIO and EMIO.
  • In the Implementation flow, you can assign package pins to the block design ports.
I recustomized my PS to have GPIO set up to use a range of MIO, and I see that my package pins in the Implementation flow are (apparently) correctly assigned to the port names from my block design.
But I don't see where the MIO range explictly links my block design ports to package pin numbers. Does Vivado do this automatically, and is there some way I can verify that the assignments are correct? If it's not automatic, how to I make these assignments?
Re: How do I verify that my MIO is assigned to a certain package pin?
Bank 0 = 0 - 25 (MIO 0 - 25)
Bank 1 = 26 - 51 (MIO 26 - 51)
Bank 2 = 52 - 77 (MIO 52 - 77)
Bank 3 = 78 - 109 (EMIO 0 - 32)
Bank 4 = 110 - 141 (EMIO 33 - 64)
Bank 5 = 142 - 173 (EMIO 65 - 95)
So, take a  particular scenario (using 1 bit GPIO via EMIO), the pin would be base_gpio + offset, or 338 + 78 = 416.
To test, use can use the commands below to toggle the LED:
echo 416 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio416/direction
echo 1 > /sys/class/gpio/gpio416/value
echo 0 > /sys/class/gpio/gpio416/value
echo 416 > /sys/class/gpio/unexport
Teacher drjohnsmith
When you defined the SOC capabilities,
    you selected which pin to use on that package.
     its fixed, but flexible in the spftware. i.e. a particular pin could be MIO or say a MOSI pin...
chapter 27 and 28
https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf
what you then need is the ascii pin tables, chapter 3
https://www.xilinx.com/support/documentation/user_guides/ug575-ultrascale-pkg-pinout.pdf
Find your device / package , and yo have a link to the ascii table of that device.
for instance this file
https://www.xilinx.com/support/packagefiles/zuppackages/xczu4cgsfvc784pkg.txt
and you will see for instance
AG15  PS_MIO0
so the MIO 0 is on pin AG15,
   and the functoin of MIO 0 is defined in your software
There HAS to be a simpler way than this,
    but I've only done this a few times, and htis way works for me, so I stick with it when I make the schematic symbols.
Scholar jg_bds
MIO assignments of Zynq Ultrascale devices are beyond automatic: they're fixed. They cannot be changed.
For a given die in a given package, 1 MIO goes to 1 pin. That's it. It doesn't go anywhere else.
Here's a completely arbitrary example.
Compare this listing from https://www.xilinx.com/support/packagefiles/zuppackages/xczu4cgsfvc784pkg.txt :
To the package diagram from UG1075:
-Joe G.
