How to connect registers to MicroBlaze?
Hi All,
How to connect registers to the MicroBlaze processor?
Should the registers be connected through the AXI bus? Is there a design example?
Thank you!
Mentor hgleamon1
Mentor
Re: How to connect registers to MicroBlaze?
You need to provide more detail about what you are trying to do.
What registers? What version of Microblaze? What does your (sub)system architecture look like?
"That which we must learn to do, we learn by doing." - Aristotle
Hi @dmitryl_home,
You have to connect that to an AXI Interconnect and connect that interconnect to the VDMA.
Follow the below link for the example design.
https://www.xilinx.com/support/documentation/application_notes/xapp1218-axi-vdma-for-kc705.pdf
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Mentor hgleamon1
Mentor
@abhinayp
How can you be so specific to such a general question?
I can only assume that you have access to information that is not contained in the original message ...
VDMA is Video DMA... How is it connected to the registers bank?
