Visitor hendrix_wang
How to do in block design to interface user logic with Bram or Bram controller using bus instead of separate signals?
Hello!
In Zync7030 design with Block Design,while PS communicating with user logic using Brams,Bram and its controller have interfaces which can zip and expand,but user logic cannot do that way,that will make the block diagram very difficult to read.So can user logic interface be a bus or harness.
Thanks!
Re: How to do in block design to interface user logic with Bram or Bram controller using bus instead of separate signals?
Ok,that's simple.First to pack user logic to an IP,then open the XML file to customerize the ports to buses.Xilinx offers lot of bus categories can cover almost any interfaces.
Hi @hendrix_wang,
Did the flow helped you to move forward?
Praveen
