Visitor aido
How to turn on PCIe on the ZC706?
Hello!
I try to follow the instructions in the UG961-Manual, but instructions in the chapter "TRD Demonstration Setup" stil doesn't work.
I use Lubuntu 14.04 instead Fedora 16, but it's ok. When I use 'lspci' with inserted board in PCIe slot, I get
$ lspci
00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation 9 Series Chipset Family USB xHCI Controller
00:16.0 Communication controller: Intel Corporation 9 Series Chipset Family ME Interface #1
00:1a.0 USB controller: Intel Corporation 9 Series Chipset Family USB EHCI Controller #2
00:1b.0 Audio device: Intel Corporation 9 Series Chipset Family HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 1 (rev d0)
00:1c.2 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 3 (rev d0)
00:1d.0 USB controller: Intel Corporation 9 Series Chipset Family USB EHCI Controller #1
00:1f.0 ISA bridge: Intel Corporation 9 Series Chipset Family Z97 LPC Controller
00:1f.2 SATA controller: Intel Corporation 9 Series Chipset Family SATA Controller [AHCI Mode]
00:1f.3 SMBus: Intel Corporation 9 Series Chipset Family SMBus Controller
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
and no ZC706 card.
quickstart.sh isn't present in the rdf0287-zc706-pcie-trd-2014-4.zip archive, and the first thing I did - try to install drivers on the host system:
$ cd ./software/host/driver
$ make
$ sudo -i
# make insert
Inserting Performance Driver
insmod: ERROR: could not insert module /home/projects/rdf0287-zc706-pcie-trd-2014-4/software/host/driver/xdma/xdma_k7.ko: File exists
/bin/mknod: missing operand after '0'
Try '/bin/mknod --help' for more information.
Makefile:32: recipe for target 'insert' failed
make: *** [insert] Error 1
I don't understand, why ZC706-board inserted in PCIe slot can't load in the QSPI mode and I don't know where to download quickstart.sh for the rdf0287-zc706-pcie-trd-2014-4.zip or what to do.
Could you help me?
Tags (2)
Visitor aido
Re: How to turn on PCIe on the ZC706?
And how to port project from Vivado 2014.4 to Vivado 2015.3?
It's needed to do instructions in http://www.wiki.xilinx.com/ZYNQ_PCIe_TRD_2014.4
in the following link in the 2nd drop down menu you can select the vivado version you are using to get the example designs
http://www.xilinx.com/products/boards-and-kits/ek-z7-zc706-g.html#documentation
