How to use VDMA on a running linux?
I'm a newbie so take it easy on me.
I've used the https://github.com/analogdevicesinc/hdl to build a design with hdmi monitor and I added an IP for image processing that I generated with vivado HLS and a VDMA to transfer data between my ip and the ddr.
I've tested the design on sdk with a standalone application and it is working fine. Now I want to run my application on a running linux on my zc702( I'm using an sd card with 2 partitions: Linaro FS and one for booting files).
I've seen that people are using <sys/mman.h> to communicate with the PL blocs like :
void configureVDMA(unsigned long vdma_physical_base)
	unsigned long int PhysicalAddress = vdma_physical_base ;
	int map_len = 0x20;
	int fd = open( "/dev/mem", O_RDWR);
	unsigned char* vdma_base_address;
	vdma_base_address = (unsigned char*)mmap(NULL, map_len, PROT_READ | PROT_WRITE, MAP_SHARED, fd, (off_t)PhysicalAddress);
	if(vdma_base_address == MAP_FAILED)
		perror("VDMA Mapping memory for absolute memory access failed.\n");
		return;
	DEBUG_Printf ("VDMA mapping 0x%x to 0x%x, size = %d\n ", (int )PhysicalAddress, (int)vdma_base_address, map_len );
munmap((void *)vdma_base_address, map_len); close(fd); }
But I got the failed message.
I don't know but should I add drivers to the kernel image "uImage" for PL blocs? and if yes, should I add drivers for both the HLS IP and VDMA?
I need your help plz
Tags (3)
Mentor
Mentor
Re: How to use VDMA on a running linux?
Hi jackolus
Could you make sure whether device tree blob file is correct or not ?
Also, could you show me device tree source file ?
Thank you.
Best regards
Here it is watari
Mentor
Mentor
Hi jackolus
Could you execute the following commands on your linux and show me the result ?
% ls /proc/device-tree/amba
% ls -l /proc/device-tree/amba_pl
% ls /boot/
Thank you
I tried the commands and here are the results:
there was no "amba_pl" in the device-tree directory
% ls /boot/
was empty
Mentor
Mentor
Hi jackolus
I confirmed your uploaded information.
According to them, the description of device tree source file and the result of "ls /proc/device-tree/amba" and "ls /proc/device-tree/amba_pl" are different.
It's very strange.
Could you explain how to generate device tree blob file to me ?
or
Could you make sure device tree blob file ?
I'm probably sure that the route cause is wrong device tree blob file.
Thank you.
You don't have to add drivers to the kernel if you are going to write userspace drivers using mmap.   If you don't have anything in the amba_pl directory it means you device tree is not correct.  Are you sure the system.dts is including your dtsi file?
jeff
Thank you both jeffdaq and watari, you are correct the problem was in the devicetree I've been using the https://github.com/analogdevicesinc/linux.git devicetree (sorry I feel stupid now).
However, now I'm having another problem. I'm using SDK to build my devicetree and when I tested it the hdmi monitor isn't working, I'm able to access the filesystem through uart but the hdmi isnt working.
Could the problem be the audio because when booting, I used to get:
ALSA device list:
  #0: HDMI monitor
However now I'm getting
ALSA device list:
  No soundcards found.
Mentor
Mentor
Hi jackolus
Could you show me your block diagram for HDMI ?
Also, how do you generate output clock frequency at HDMI ?
Thank you.
Hello watari,
Thank you for responding.
I couldn't attatch my block design so here it is https://drive.google.com/open?id=0BzR7agsHdJabbGxpUGpodVMzVkE.
However, can you please check if I am building the devicetree correctly?
I'm using this repository : https://github.com/Xilinx/device-tree-xlnx
and the default settings :
execpt for bootargs I'm using: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
Am I doing something wrong?
Mentor
Mentor
Hi jackolus
I can't access https://drive.google.com/open?id=0BzR7agsHdJabbGxpUGpodVMzVkE.
Could you show me block diagram ?
Also could you show me device tree source file, what you want to build and result by "ls" command, if you want that I confirm it ?
Thank you.
Hello watari,
Here is he design and the files generated by SDK to form the device tree.
Mentor
Mentor
Hi jackolus
I mention to you.
1) HDMI issue
I guess you connect HDMI monitor via HDMA calue with AUX/Audio.
Hence you find this message.
> ALSA device list:
>   #0: HDMI monitor
2) device-tree issue
I already confirmed your uploaded files.
You define axi_vdma_0 in pl.dtsi file.
However, I can't find this definition in your posted picutre which is generated by "ls /proc/device-tree/amba" and "ls /proc/device-tree/amba_pl" to make sure recognition of device tree.
Hence I suspect you have mistake to generate device tree blob file.
Could you execute the following command to make sure the definition of device tree ?
% dtc -I dtb -O dts -o <output dts file name> <input dtb file name>
After that, you get "<output dts file name>" file as device tree source file and you can confirm it.
Could you confirm it, too ?
Thank you.
Hello watari,
The pictures I've posted where when I was using the analogdevicesinc from github. Now I'm generating my own devicetree using SDK and here are the results:
