Participant leoeltipo
IP With block design and microblaze
I want to do something that should be simple, but apparently it is not. I want to create a new IP. That new IP is created in a new project, using a block design as it eases connecting stuff. My IP also includes a microblaze processor.
I package my IP but, when I instantiate it in another project, the synthesis and implementation go well, but the processor is not in the address map. If I export the hardware, the processor does not show up in Xilinx SDK. Is there any way to package a custom IP with a microblaze, and expose the processor to the top level design that instantiates it?
By the way, Xilinx folks should find a better way of creating and easily editing IPs that contain block designs. I could not find the way to do this clean, and I always have to keep a vivado project just for editing the IP.
Leo
Re: IP With block design and microblaze
Hi @leoeltipo ,
We already have published an AR to package the Microblaze in BD and using it in another project. Please refer this AR: https://www.xilinx.com/support/answers/67083.html
Best Regards,
Srikanth
Hi @savula ,
Thanks for the repply seems very interesting. However, I do not want to add the ELF file. I want the Microblaze to be discovered at the top level design. I could do this, but when I export the hardware, the microblaze in the IP does not get recognized by SDK so I cannot program it. Is there a way around it?
Thanks again,
Leo
