Is it wrong to use LMB to data manipulation?
im implementing a freertos application on microblaze.
i see an exception come up always on axi data, i store some data on LMB, i haven't implemented FAULT_PROTECTION.
maybe is this the cause?
Re: Is it wrong to use LMB to data manipulation?
Hi @mrbietola,
Could you please let us know how your application look like?
When the exception APIs (I mean after what operation) does executed?
Praveen
Maybe is not related to LMB. I see that the EAR register reports the address of uartlite TX fifo.
The application sends data and receives data from/to Mailboxes and some uartlite. These are subdivided in different task enabled by interrupts.
Suddently it crashes. The ESR register value is C84 , so i desumed the problem is caused by delay slot instruction, exception caused by DLMB
Maybe the problem is caused by xil_printf that is not reentrant.
Is the uartlite driver reentrant?
