Observer noami9226@
JTAG-to-AXI IP Core
Is it possible to write a testbech code to simulate my design shown in the pictureee.jpg?
Re: JTAG-to-AXI IP Core
You should be able to. Refer to chapter 5 in the PG for commands. If possible, generate example design and see what is done there.
Steve Markgraf - Distinguished FPGA Design & Support Engineer E5-E
www.designlinxhs.com
It appears that the JTAG to AXI Master does not support simulation.
This is from the example design test bench:
$display("-------------------------------------------------------");
$display("JTAG_AXI do not support simulation");
$display("Test completed successfully");
$finish;
The commands listed in chapter 5 must be for running on hardware.
I think you could simulate design, but you would need to use an AXI Traffic Generator in AXI4-Lite mode and add another MAster and SLave port to your interconnect.
Sorry for the misinformation.
Observer noami9226@
Many thanks to you.
