Visitor vivekv80
LWIP application Microzed 7020 -> read and print buffer before echo
I have a bare metal application on a MicroZed 7020 running the stock LWIP server application. I used the guidelines provided here http://www.fpgadeveloper.com/2016/01/running-a-lwip-echo-server-on-a-multi-port-ethernet-design.html to test the application. Everything works as expected. I would like to save and print the contents of the data packets sent to the ethernet port. I checked the echo.c -> start_application function to get an idea on the buffers(p->payload) that can be printed and could not figure it out. Is it possible for the application to save the buffer contents and print it as well?
Thanks in advance.
Tags (3)
Re: LWIP application Microzed 7020 -> read and print buffer before echo
