Observer hchen213
Large Matrix Tranpose
Hello All,
I have a matrix that is about 10k by 10k in size, and it is transferred from the computer to the PS-side DDR. What would be the most efficient way to transpose it?
I believe DMA would not be needed, because we can not utilize the burst feature. Is there any other tools that allows fast data transfer between different DDR memory locations?
Scholar hbucher
Re: Large Matrix Tranpose
@hchen213
Do you need to transpose it? Because transposition is very costly while a frequent operation, most matrix libraries would just set a flag to indicate that the matrix is transposed - relative to their position in memory.
When it comes to using the matrix, say matrix vs vector multiplication, two algos are used to multiply it - one for the normal matrix and one for the transposed. Same for element access etc.
This way you avoid entirely a costly operation with the tradeoff of a few more bytes of code.
That said, You could create a component in HLS to perform this operation and connect it through a full AXI interface and connect it to the slave HP port on the ZYNQ.
Observer hchen213
@hbucher
Right now, I am using the data mover IP on the PL side to read and write to PS DDR memory through the High Performance AXI connection. I can get a decent data transfer rate by using a 128 bit bus width with a large burst size. However, If I have to read the transposed matrix out, I can only read one element at a time, then increment the DDR address and read the next one, this would slow down the data transfer rate dramatically.
I am wondering if there is any better tools that I am not aware of for this kind of operation?
Scholar hbucher
The HP ports are very slow if compared to DDR speed - some 10x slower
I wonder if you transpose with the ARM it would be faster.
Or perhaps move your heavy stuff/matrices to PL side DDR.
Observer hchen213
@hbucher
Thanks for your input.
I am using the ZCU102 evaluation board, and the PL-DDR is not large enough, also MIG takes quite bit of space in the PL.
I did tested using ARM for transpose, and it was faster than I expected. But I am not sure if it is fast enough for my application.
There are 4 HP ports, would using all four of them give me a higher data rate?
Scholar hbucher
@hchen213
Yes, I think so.
Have a look at this SDK performance manual
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug1145-sdk-system-performance.pdf
Chapter 7 "Evaluating High-Performance Ports" shows many statistics about using all ports simultaneously
This video is also a good overview
https://www.xilinx.com/video/soc/accelerating-system-performance-zynq.html
