Observer saikiran.k
Mcroblaze read speeds
hi,
Can anyone one explain at what speed microblaze can perform read operations with BRAMS inside FPGA.
relation between the read data rate and the operating frequency of the FPGA.
Re: Mcroblaze read speeds
Hi @saikiran.k,
The area-optimized version of MicroBlaze, which uses a 3-stage pipeline, sacrifices clock frequency for reduced logic area.
The performance-optimized version expands the execution pipeline to 5 stages, allowing top speeds of more than 700 MHz (on Virtex UltraScale+ FPGA family).
You can refer the Performance and Resource Utilization section from the below link.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug984-vivado-microblaze-ref.pdf
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
