Observer zdicklin
Microblaze UART ISR hangs on even-numbered characters
Reposting, as this was marked as spam for some reason...
I've been setting up an application that reads data from the UART with ISR. I wrote a simple echo application, but it behaved a little weird and inconsistent. Like, sometimes it would work great, others just kind of hang. To dumb it down further for troubleshooting and make sure it's not an issue of the ISR handing, I removed the echo and just have a bank of LEDs counting up each time the ISR is called.
With a bit of research, I found it hangs consistently on keys with even-numbered ASCII values. For example, if I hold down the 'A' key, the ISR is called repeatedly as expected. If I jam on the 'B' key, it might get called a few times but then eventually hang. Sometimes it won't receive at all.
I found all these letters with even-numbered ASCII values all jam eventually:
b 62
d 64
f 66
h 68
j 6a
l 6c
n 6e
p 70
r 72
t 74
v 76
x 78
z 7a
All of their odd-numbered counterparts work great.
This is only an issue when using the interrupt. I have no issue receiving data if I do it in my main loop.
Any thoughts? I've tried messing with connection settings (flow control, etc), the UART AXI clock, etc, but no luck.
Board is an Arty A7
Observer zdicklin
Re: Microblaze UART ISR hangs on even-numbered characters
Another clue- I can only press an even-numbered character (b, d, f, etc) 15 times before they're unavailable. It can be any combination of these keys: 8 B's, 4 D's, 4 X's, and it stops. Then I have to press odd keys to accept them again.
Here's a video of this in action:
https://www.icloud.com/photos/#08ktjuSEiNl-dwoter92CzVew
Also, I attached my code.
Scholar dgisselq
@zdicklin,
Is there any way you can get a trace from your design?  Something showing what is going on, and that won't hang when the microblaze hangs?
Dan
Observer zdicklin
Alright, I figured it out. My argument to the UART interrupt handler was a UINTPTR type.
void uart_int_handler(UINTPTR *baseaddr_p) {
   ... do stuff
All the addition is done with macros. The status register offset is 8 - which when added to a UINTPTR is 32 bytes- which memory maps back to the RX FIFO register. So, an odd-numbered character in the FIFO meant "Valid RX FIFO Data", and an even-numbered one meant "No RX FIFO Data" ;)
By changing the type to something else (void*), the addition of 8 is just 8 bytes, correctly mapping to the status register.
