Observer kadir_cel
Multichannel DMA for parallel working IP Cores
We are developing a crypto module using Xilinx Zynq. We have different IP Cores that will work parallel at the same time. We want that a user can initiate a hash operation and an AES encryption at the same time, data will stream from memory to IP Cores over different AXI-Stream interfaces and IP cores work parallel. Is it possible using multiple DMA engines for each of the IP Cores in the design?
We are working on Vivado 2017.1 and it seems like that MCDMA is not supported. Is there any difference between AXI DMA with MC support and MCDMA? Can I use AXI DMA for our purpose? Are there usable drivers for Linux systems of DMA IP Core?
Voyager
Voyager
Re: Multichannel DMA for parallel working IP Cores
The AXI DMA should work for your implementation.  If you want to run two independent processing paths at the same time, it would make sense to use two AXI DMAs.  One for each operation.  The AXI DMA is compatible with Linux.
Here is a link I found on the forums that might help you get started:
https://lauri.xn--vsandi-pxa.com/hdl/zynq/xilinx-dma.html
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Voyager
Voyager
Community Manager
Community Manager
It is not recommended to use AXI DMA in multi-channel mode (refer to the below snippet from the latest version of PG021).
In your case, you can instantiate oneAXI DMA IPs for each channel.
